Machine parameter
Machine parameter
CuttingEdgeManufacturing
Machine parameter
Hey guys, im editing my setup sheet. and i would like to add in what machine it is to be run on, automatically using a parameter for the machine that i can add into the spreadsheet. but cannot seem to find the parameter or expression? any help? can't seem to find a list of parameter for f360 online. thought it would be an easy thing to find
seth.madore
Did you post out with the Dump.cps? That "should" give you all the info that's available.
Seth Madore
is that in the standard post list you get? didnt know about that one
seth.madore
Yep! It will give you every parameter that's passed through the post engine
Seth Madore
eh unfortunately i didnt see it. hopefully it can be added. would be really cool to put the machine and post into the set up sheet.
thanks for the help seth, i never knew about the dump post!
seth.madore
Really? It does show up, but holy cow, is it quite the string of text.....
 onParameter('machine-config', '<?xml version="1.0" encoding="UTF-16" standalone="no" ?><machine xmlns="http://www.hsmworks.com/xml/2009/machine" version="1.0"><vendor>Autodesk</vendor><description>Doosan Lynx</description><machining jet="no" milling="yes" turning="yes" wire="no"/><tooling maximumToolDiameter="0mm" maximumToolLength="0mm" maximumToolWeight="0kg" numberOfTools="0" toolChanger="yes" toolPreload="yes"/><machiningTime ratio="1" toolChangeTime="15s"/><coolant options="FLOOD MIST THROUGH_TOOL AIR AIR_THROUGH_TOOL SUCTION FLOOD_MIST FLOOD_THROUGH_TOOL"/><capabilities workOffsets="100"/><spindle axis="0 0 1"/><post/><simulation retractOnIndexing="yes" shortestAngularRotation="yes" wcs="0mm 0mm 0mm"/><multiAxis adjust="yes" angle="10deg" cone="3deg" linearizationTolerance="0.04mm" method="off" reconfigure="yes" tolerance="0.04mm"/><axis id="X" link="table" range="0mm 0mm" tcp="no"/><axis id="Y" link="table" range="0mm 0mm" tcp="no"/><axis id="Z" link="table" range="0mm 0mm" tcp="no"/><axis actuator
Seth Madore
sorry, ive never really dove into this sort of thing before.. so it would be like "$Machine-config.description"? or am i missing it here.
