preview functionality Set up sheets
CuttingEdgeManufacturing
Hey guys just seen theres a beta for the set up sheets  customizer. i wanted to play with it this morning so i made a custom one. went to try it, but it doesnt give an option to pick my new set up sheet. just automatically does the default with all the extra content i didnt want.
anyone know if you can, and if possible how to switch between the default and others.
mattdlr89
It's possible to switch between them. The only way I have worked it out is the following (I'm not sure if this is intended to be like this or a bug/work in progress).
To be able to select the customised set up sheet you must select setup sheet from your NC Programs in the command browser. This will allow you to select a folder then you can select whichever template you like. Screenshot below.
