Machine is not showing during simulation
MatthewECornelius
MatthewECornelius
Hello Forum!
I am in the process of testing a machine we want to purchase using Fusion 360. I have gone through setting the machine model up and selected a part we make that already had some 3 axis tool paths. I will be adding some 5 axis moves, but currently I cannot get the machine to show up when I simulate the paths that were developed on our 3 axis mill. Why does the machine model go away when I want to simulate? File is attached, thanks in advance.
Matt
colin.reidKY5GD
Hi Matt,
I've downloaded the file and all ran as expected for me, the machine was present whilst the simulation was running.
Could you have selected simulate rather than simulate with machine in error?
Is machine selected in the simulation dialog box?
Colin
programming2C78B
Just fyi but you wont have to do force tool changes for a Haas if you just enable Setting 36 on the controller and start from the line after the tool change.
Please click "Accept Solution" if what I wrote solved your issue!
MatthewECornelius
I am such a fool 🤣. I forgot that there are two simulation buttons. I get today's dummy award on the forum!
