Machine definition error
dames123
dames123
It looks like they changed the way machine builder works in the last update. Now when I try to load a machine I get this error.
I would upload the file but my IT dept. is blocking uploads at the moment.
a.laasW8M6T
Hi
Have you tried updating the machine model by right clicking on the icon and selecting update machine model?
alternatively try this
Remove the machine from any setups
then go to the machine library and delete the machine from the document
Then re-pick the machine from your machine library in the setups.
Andrew Laas
Senior Machinist, Scott Automation
dames123
Thank you sir!! I never realized the file saves the machine even when you remove it from the setup. I had three machines in there.
