Sorry its taken so long to get back.
File format is ok, but doesnt have a Machine associated with it, its an unfortunate side affect of the way its handled in fusion.
The proper way to export it is to go into the machine Library and right click on the machine and click "export"
I was able to create a working machine from that file, however i had to recreate the kinematics from scratch.
I'm not sure why you are having trouble, I'd maybe suggest starting again from scratch, or export the machine through the machine library and attach here
You will need to modify your model slightly also to include clearances between all the moving parts.
Currently like you see here the x axis rails to body have no gap and this will cause problems in the future when machine collision detection becomes active.
You need clearance like this:
Hope that helps
Cheers
Andrew
Andrew Laas
Senior Machinist, Scott Automation
