Machine Builder Utility / Post Processor / Fixture Attachment Point - Issue
tobiasSCLW4
tobiasSCLW4
I took the model I have of my machine and used the Machine Builder to make a digital twin. That process was fairly straightforward. The Post processor I normally use does not support Machine simulation. I downloaded a generic Fanuc post that does support machine sim.
In my CAM Setup I select my Machine, which is new to me. I select my Model, WSC, Stock as I normally do. Setting the fixture is new to me as well. I select the vise and adapter plate I set the Fixture attachment point to the center of the back of the plate. I thought this would snap that location to the "origin" that I selected in the machine builder. But I'm not getting the result I wanted.
any ideas? I feel like I've tried everything
unfortunately my files were too big to attach.
serge.quiblier
Hi @tobiasSCLW4
can you please share your file, either using an archive or sharing a public link?
Because just looking at the picture can't help us diagnose the problem.
You may have entered an offset during the placement of the part, or selected a location, different than what you intended...
You can either share a link to your Fusion file. See:
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
or you can save an archive (f3d, or f3z) and share it on the forum
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Cheers
Serge.Q
Technical Consultant
cam.autodesk.com
tobiasSCLW4
Thanks for the reply Serge. I actually figured out my problem shortly after I posted this. Which was a few months ago now. I don't exactly remember how but it's fixed now.
Thanks again
-Tobias
serge.quiblier
Hi @tobiasSCLW4
either you have tweaked the Selection priority between face, edge... but I doubt.
Or you have played with differents options in this dialog
Using the Fixture box point instead of a selected point, tuning with the xyz distance at the bottom...
Or eventually selecting differently the table attach point.
Who knows.
If you have a working workflow, that what matters.
Cheers.
Serge.Q
cam.autodesk.com
