MACH3 g43 and g54 post process problems
ANDERSONRODANDCHOPPER
Message 1 of 23
I am new to CAM and more specifically fusion 360 CAM.   I am running MACH3 as well.    My problem is after I have homed and zero'd my machine and start cycle the machine runs the program offset left during the 1st facing operation at the correct Z and then during the 2D adaptive operation runs approx .5" high on the z with the same left offset.    Same tool in both operations.   From what I have read this may be a G43 and/or a G54 problem in my code.   I have changed my post process to .tap file extension and do not use G28 and that has helped my "bad character, K word" and Z crashing problems.    My question is how do I set up my post process to eliminate this "offset" or is this a setting in MACH3 I need to adjust.    I do not want to edit code on every program I run if possible.   This seems very time consuming and considering the fact that I don't know what I am doing I feel it sets me up for more problems....
I tried to post the code but it wont let me attach a .TAP file  Is their a way to work around this?
Thank you for your time.
Josh
Replies (22)
Message 21 of 23
daniel_lyall
@ANDERSONRODANDCHOPPER just one thing when you home your Z it should activate the switch then back off the switch then Zero the Z axis machine home so when it does the G28 it should not crash.
if it does you have backlash or losing steps or it is not backing off properly.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 22 of 23
Thank you I have it working correctly now.
Message 23 of 23
daniel_lyall
all good
Daniel Lyall
The Big Boss
Mach3 User
