MACH3 G-code - Bad Character and K word problems
Message 1 of 21
Hi
having problems with Gcode that actually someone very kindly done for me in an original post. as the title suggest, keep having errors with Bad character and K word.
there are so many lines that I have been at it for 2 days now and only managed to get hald way through but surely there must be another way of sorting it. I use Mach 3 programme when milling if that makes a difference.
any help would be great. ill attach the gcode with this post
Replies (20)
Message 2 of 21
seth.madore
What Post Processor are you using?
Are you saying that your machine doesn't support "K" values?
I recall hearing that Mach3 didn't care to much for I/J, but rather preferred R callouts. You can switch your Post Dialog to "Use Radius" and it will use R's instead.
The other option is to tweak the post processor so it only outputs arcs in the XY plane.
Seth Madore
Message 3 of 21
Thanks for the reply.
Someone had done done it for me so not sure what post process they used but will try your suggestion.
Will let let you know.
Message 4 of 21
Hi
so changed in the post process: Arc radius and change to yes. now coming up on Mach 3 R I J and K words all missing from Arc
do you know in the post process where I would find the way to change the letters as you suggested?
thanks
Message 5 of 21
seth.madore
I"m sorry, I don't understand. All words are missing, or some are still there?
Seth Madore
Message 6 of 21
I have attached the image from mach 3. hopefully that helps.
Message 7 of 21
seth.madore
Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply.
Trying to rule out a couple other things..
Seth Madore
Message 8 of 21
here is the file
Message 9 of 21
seth.madore
Using the generic Mach3 post processor, I get this:
Why you are getting R's turning into P's, I'm at a loss....
Seth Madore
Message 10 of 21
hi
thanks for the reply.
in the post process stage there is drop down list of different programmes. should I be clicking Mach 3? I have never needed to do this but do you think that might change it?
Message 11 of 21
seth.madore
Oh! Yeah! If you are not selecting the correct Post Processor, you are gonna have a bad time about this...
Seth Madore
Message 12 of 21
im having an absolute nightmare with this but determined to get it. corrected the post process now when the programme runs, there are no errors but it stops at line 2 and no idea what it is now.
has anyone any ideas?
Message 13 of 21
daniel_lyall
Can you post the model and the Gcode you produced from fusion?
Otherwise, it is a guess what the problem it can be many things making it stop from you calling mach3 names to the
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 14 of 21
Hi
attached is the file from fusion and the gcode for mach 3
Message 15 of 21
it wont let me upload the gcode file
Message 16 of 21
here is the start of the code
Message 17 of 21
daniel_lyall
You change it to .txt or put it in a zip file
Daniel Lyall
The Big Boss
Mach3 User
Message 18 of 21
ok
Message 19 of 21
daniel_lyall
That Gcode is fine on my machine
Mach3 has a bug where it puts a warning out and stops the machine from working doing a restart clears it if it does not clear it is correct that something is wrong.
Mach3 is lose with what codes it can run K is one it can use if you click on the M-Codes button on the Program run screen it shows what letters are fine in Mach3.
Daniel Lyall
The Big Boss
Mach3 User
Message 20 of 21
ok thanks for that.
this might sound really stupid but see when your trying to run a programme on mach 3 but you haven't connected the code to the machine (i.e. simulation run) can that sometimes stop it from running?
thanks for your help so far. its really appreciated
