M6 at the beginning of the code
novaknovak921
novaknovak921
I am wondering how to disable post processor (if there is a fault) or something else so that M6 is not embedded at the beginning of the code?
I don't have an ATC and I manually load the tool into the spindle, set the Z zero, and then run the code. Because of M6 in the code, all the time I have to edit the code and delete it.
Milos
  • M6
a.laasW8M6T
Hi
This is pretty easy to do but we need your post processor
can you upload it here?
You can export it from the post library
Andrew Laas
Senior Machinist, Scott Automation
novaknovak921
Thanks for looking into it.
Here it is.
a.laasW8M6T
Hi
Heres the post with M6 removed
Andrew Laas
novaknovak921
It is working. Perfect. Thanks.
M
