M Code problem
M Code problem
Message 1 of 13
M Code problem
Hi, I'm using Fusion 360 as a student and been doing some CAM. When I put my file as a ".nc" I have always have this M26 code that is generated and I do not understand what it is for and I wondered how to remove or disable if possible.
Replies (12)
Message 2 of 13
zwelsh91
To help the community better assist with your question, Can you please share your file and what Post Processor you are using to generate machine code?
Zak Welsh
Zakary Welsh Machine LLC
Message 3 of 13
Here is my post processor (in fusion 360) and here is the “.nc” file;
Message 4 of 13
randyT9V9C
Your attachments didn't come through.
Is it generating an error on your control? You may need to comment it out of your post processor. Remember the generic post processors sometimes need to be edited to taste.
M26  will vary in purpose depending on the machine/control. You'll need to look it up in your manual. I have one machine that uses M26 to reset the machine zero, another that does clear point tool change, and on my lathe it retracts the tail stock. And I have machines that wouldn't know what to do with it. 😉
Message 5 of 13
It is not a error that M26, I just want to know what activates it and how to disable it in Fusion so it doesn’t generate the M26
Thank you
Message 6 of 13
randyT9V9C
What post processor are you using?
Message 7 of 13
I’m using the one called “Brackets” in Fusion 360
Message 8 of 13
randyT9V9C
Brackets is the editor that your generated g-code is viewed in following post processing. When you post process, what vendor and post are you selecting from the post configuration dialog? What model of machine do you have?
Message 9 of 13
There’s a place to enter what machine you have? In my case it’s a cnc router and I don’t really go into details with what vendor I put in, but does it make a difference?
Message 10 of 13
randyT9V9C
You need to select a post processor that best matches your machine/controller. Every machine is a little different. G-code generated for one machine may have un-intended results on another. Post processors are very much machine/control specific.
What cnc machine are you running?
Message 11 of 13
My machine is a cnc router for milling, it’s called CNC3018 but it’s not made by any company and I don’t know what king of gcode my machine understands
Message 12 of 13
randyT9V9C
I believe the CNC3018 is GRBL based. Try using the GRBL post, it is in the list of pre-installed posts.
Alternatively you can download the latest version here:
https://cam.autodesk.com/hsmposts
Looking at the sample code it does not have the M26 included that was causing you issues.
Message 13 of 13
I see, I didn’t know what GRBL meant. Now it more sens, thank you very much, I’ll try this change soon and let you know,
Thanks again
