Linking Tool Libraries?
- Mute
- Permalink
- Report
So this morning I had a thought relating to my cloud tool libraries. For every machine in my shop, I have created a tool library with pre-loaded tools in the machine. Obviously, this just makes programming and set up much more efficient.
However, let's say I decide to change a tool in the library, then every program I have written using that library will need to be updated. This isn't a huge deal as whenever I have a repeat job, I always run through the program quickly to make sure everything is ok. While doing so, I also verify the tooling in the program matches what is in my machines. If not, then I just quickly update the tool and I'm up and running. I have written 1000's of programs over the last few years using this method, and its not a big deal.
This morning a thought occurred to me that it would be nice to be able to link a tool in a cloud library in much the same fashion that we can link models from other files. So for example, right now I have a roughing tool as my first tool in my 5-axis machine. The tool finally met its doom, and I replaced it with a slightly different tool that I wanted to try out for a bit. Now whenever I pull up a previously written program, I will have to update tool 1. Again, not a big deal. Now my cloud library for that machine has been changed.
It would be pretty awesome if there was a way that when you assign a tool from your cloud library to the current part being fabricated, that the tool is linked back to that cloud library. Just like when you drag in files to your existing file, it has the linked icon next to it. Any time you update that model in its original file and save it, any new file that is associated with that original file just needs a quick update and you're back up and running with a simple click or two. It would be awesome if that same method worked with tools in the tool library. You assign the tool to the job, and if at any point in the future the tool is updated, then you just regenerate the toolpath and the tool is also updated in the process. If you ever decide you need to modify the tool and you don't want it to affect the main cloud library, you could "break link" just like you would with regular models in the design workspace.
I don't know if something like this exists already or not, but it was something that popped up this morning, and I thought it would be a good idea to get it out there in case there is something like this that already exists and I'm just unaware of it.
I don't know how many people would find this beneficial, but I think it would be a nice feature if it existed.
I was thinking that it woul
Christopher Cooper
