Lathe Trace Op will not follow my full sketch only part of it
ChevelleNV
ChevelleNV
I am trying to use the new Trace operation on the Turning tab. I created a sketch for it to follow, but it will only follow part of the sketch, any ideas why it wont cut the way I want it to?
a.laasW8M6T
Hi
Without the file its hard to tell.
I see you have 3 open chains selected but it should only be one continuous chain.
If you could upload your file here it will be much easier to diagnose
Goto File>Export>Save as .f3d/.f3z
Andrew Laas
Senior Machinist, Scott Automation
ChevelleNV
Unfortunately I am unable to share my model for various reasons, and fusion wont allow me to select the whole chain as one chain and it will not let me choose it as a sketch profile either.  One thing i have noticed in trying to get this working, is if I only select the third part of the sketched line it will give me the path shown on the images. but if I only select the first or even the second part of the sketch it will give me an empty cutting area error.
Debug: Writing jobfile to C:\Users\sales\AppData\Local\Temp\Fusion360CAM\15532-1\operation332.ironjob
Debug: Writing jobfile to C:\Users\sales\AppData\Local\Temp\Fusion360CAM\15532-1\operation332.hsm-job
Debug: Using jobfile C:\Users\sales\AppData\Local\Temp\Fusion360CAM\15532-1\operation332.ironjob
Debug: Initialization elapsed time: 2 ms
Debug: Using CAM kernel from: C:\Users\sales\AppData\Local\Autodesk\webdeploy\production\ca305acf3852cfce8e837ee5435adf649bc398ca\Applications\CAM360\camkernel.exe
Debug: Command line: camkernel -p "operation332.ironjob"
Error: Empty cutting area.
Debug: Autodesk dcamcomponents 1.323.1 pm12961
Autodesk CAM Kernel 3.224.1 (0a37658b) x64 STABLE vs2022 0a37658bade24eb75faae1b957b6937bd74396d6 2025/08/07 15:00
Warning: Empty toolpath.
Debug: Total processing time: 62 ms
Debug: Total elapsed time: 82 ms
Invalidated: Generation failed
ChevelleNV
not sure what's going on but i replied to this thread twice and now both replies are gone
ChevelleNV
found the problem, even though the model was a spun profile I had to do a extrusion forcing the flatness of the top of the part to get it to trace my sketch.... ya explain that one. I took .001 off of the part dia. and everything started working
