lathe Live tooling lathe without Y axis
bigbrad73
bigbrad73
I have a mazak lathe with live tooling. I am wanting to start using fusion for the lathe more. Current they use the conversational programing. Is anyone else programing a mazak qt300 with live tooling and no Y axis with fusion? I was messing around trying to thread mill a thread but its moving in the Y axis. Is that something the post will convert to the C or what? Any help will be appreciated.  Also wondering about pockets and engraving in the face. Same issue with that.
seth.madore
You will need a Mazak mill/turn lathe post, and I'm actually suprised to see that there arn't even 2 axis lathe posts in the HSM Post Library...
The motion would largely be handled in the Post Processor.
Seth Madore
bigbrad73
so there is no mazak lathe guys running fusion?
Marco.Takx
Hi @bigbrad73,
Yes there are, but they buy a post processor at there local reseller. Or let them create one.
HSM post adjustments needed? Find your right contact here.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
utekcnc
There's not just an abundance of people using Fusion for their lathes.   I just started and am transitioning from Gibbs to Fusion and am finding that out.
seth.madore
The lathe portion of Fusion is honestly, still in it's infancy, when compared to other more established CAM packages. That said, I know that the Lathe dev team is working very hard at bringing a decent level of usability to the table, it's just that these things take time.
I also know that the Post development team does have a ticket in to create a Mazak QuickTurn post. I don't have any idea on timeline, sorry.
Seth Madore
utekcnc
The update last Friday had some nice lathe improvements.   At IMTS I spent quite a while talking to a couple of the people in charge of the lathe side of Fusion and they assured me it's fairly high on the priority list right now.
