- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I am designing a bracket out of 3/16" steel that I will be laser cutting out.
On one side I would like to make some marking lines (to speed up part aligning during production before welding so I don't have to measure every time). Surface markings only, not all the way through. Another reason is I'd like to mark part numbers onto the surface of each part for easy identification.
Laser is outsourced, not in-house. 4000W capacity. I've seen it done elsewhere and I'd like to know how I should design my part so any cutting service provider will produce the same result.
I've attached images that show projected lines where i will be welding another part to. Thank you in advance.
