Keyhole toolpath
Keyhole toolpath
Message 1 of 39
Keyhole toolpath
I've been trying to figure out how to setup a toolpath to cut a keyhole in the back of a part, so that I can hang it on the wall like a picture frame, and am having very little luck.  Currently, I am using a 2D slot toolpath with a plunge ramp, and that gets me half way there, but I haven't found a way yet to get the toolpath to basically reverse and back out the way it went in.  Here's a picture to hopefully help illustrate:
Jim
Replies (38)
Message 21 of 39
matthew.nichols
that was an awesome TV show!Smiley Happy
Matthew Nichols
Adoption Specialist - MFG
Message 22 of 39
I am 2 episodes in and it has not told me why my tool is starting below the stock lol.....................am I doing it right?
Message 23 of 39
Steinwerks
Yes you are, there's definitely a bug of some sort going on here. No height adjustments either in distance or geometry reference seem to make a difference.
@Anonymous can you take a look at @Anonymous 's file? Turning off Smoothing let the toolpath generate the initial clearance height but the tool still rapids into the stock.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 24 of 39
So I finally tested the keyhole toolpath on my project and 10 ipm seems to work great for plunging and radial movement but I do have one issue that I am not sure how to correct.
When the tool path starts the tool in plunging down at rapid feed rate (my machine 800 ipm) and just knicks the surface of the stock I think 10 or 20 thousands and then lowers the feedrate to 10 ipm. This is a bit of a problem and I believe will break my tool if it happens to much
When I simulate the tool path is shows a collision when you first start but as soon as it enters the stock the collision stops dose anyone know why this is happening? I have attached the .f3d file for you to look at.
I think a work around might be to lower the rapid rate to 10 ipm but I really dont want to do that because it will add extra time to the cycle time
I would very much like to get in touch with someone from Fusion 360 regarding this issue and hopefully resolve it
Message 25 of 39
xander.luciano
While this still seems like it might be a bug, if you go back and look at post 19, I described a way to create this toolpath that should suit for your needs.
Here you can see the toolpath will use a lead-in (green line) from the feedheight instead of a rapid movement (yellow line) into the stock.
6q2wyb6
I also attached the .f3d with the updated toolpath.
Hopefully this is what you are looking for! Let me know if this solves your issue 🙂
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Message 26 of 39
Hey thank you for that I see that you have put another sketch in of a straight line and just had the tool follow that
How do you and why do you pin the sketch in the modeling tab?
Message 27 of 39
Steinwerks
@xander.luciano
He shouldn't be experiencing a crash though. This should be able to be set with height settings and it isn't, therefor it sure looks like a bug to me since the toolpath is correct otherwise, and without using a workaround such as a sketch line.
Neal Stein
Find me on:
Message 28 of 39
xander.luciano
@Anonymous I think you're referring to the sketch visibility when you say pin, correct? If so The light bulb in the feature tree will toggle it's visibility. I made it visible so that I could select the sketch line in the CAM environment.
@Steinwerks Correct, it does look like a bug. He should still be able to set the height, but what makes the way I did this a "workaround"? It's still a completely valid way of creating toolpaths. 😉 Similar to how one might make a sketch profile to constrain a 3D toolpath.
Xander Luciano
Message 29 of 39
Steinwerks
If the idea is to avoid a bug, it's a workaround. This isn't special geometry IMO.
Neal Stein
Find me on:
Message 30 of 39
Hello thanks for the reply
I do think that it is a bug in the old tool path due the fact that the tool should never rapid below the level of the stock in any generated tool path
and plus it shows a collision in the cam simulation
However this will work for my current situation but it does add time to the overall design process of the part
And no not the visibility of the sketch the pin(or ground) icon looks like it is turned on with the sketch that you provided  here is a screen shot
Message 31 of 39
fritter63
Clamp a guide board on the back of the piece, put it in a plunge router, run the router along the guide board. plunge, push, pull, unplunge. Setup up start blocks on both ends for accuracy.
You'll be done in 10 minutes. 😉
Message 32 of 39
In 2016 we build a fixture like this
And we are done in 16 seconds!! with every piece done being the same...........ehh a little quicker than 10 minutes me thinks?
Message 33 of 39
or fixtures like this for multiple operations
Message 34 of 39
cj.abraham
I'm a bit late to the game on this one. Xander's solution with the trace operation is the ideal case. I've attached a simplified version of your part to show you the best way to leverage sketches for both CAM and modeling. Hopefully this model will also generate correctly for you. The one caveat of the trace operation is that the selected contour is where the tool tip will be for cutting. This means that there is no "Top" or "Bottom" heights to be set, unlike a 2D contour with compensation turned "off" (which behaves the same as trace!). So long as the tool is below the feed plane, the tool will be using one of the four feedrates (plunge, lead-in/out, cutting). Anything above that can be a rapid move.
Message 35 of 39
Steinwerks
@cj.abraham
This is much clearer in HSMWorks of course, and if there is going to be a "Feed Height" that is settable from any reference, it needs to obey that. I also realize there are exceptions such as Adaptive, but that uses a Safe Distance which Trace does not have.
Normally I would be sympathetic to a Trace operation rapids but not when it violates very explicit settings available in the UI.
Edit: Had to go back and look at my own example! Trace does have a Safe Distance and mine was set at .25, which puts the toolpath 1/16" above the entry position, violating the Feed and Retract heights respectively, but not crashing into the stock. Increasing the Safe Distance to .3125 puts it 1/8" over the stock before feeding into the part, using a Lead-in linking even though the Leads are turned off. I think some explanation of exactly how this is being calculated is warranted.
Neal Stein
Find me on:
Message 36 of 39
cj.abraham
@Steinwerks
My trace operation in the archive file I attached in my previous post respects the feed height regardless of safe distance. Not sure what you are referring to here.
Message 37 of 39
Steinwerks
@cj.abraham
See post 7. Safe Distance is not intuitive although that file doesn't crash into the stock.
Neal Stein
Find me on:
Message 38 of 39
jtromboukis
I had some success selecting this path in the photo and doing a 2D contour operation. The bit exits where it's supposed to. I'm new to Fusion so I'm trying to figure out how to get the start point of the bit where its should be. Right now the center of the bit starts next to the WCS. If anybody can help me with that, thank you
Message 39 of 39
Thanks for your input on the keyhole operation. I knew I wanted to do a trace operation to achieve the desired result. But I didn't have "repeat passes" and "both ways" checked under the Passes tab. Once I made that change, the operation worked perfectly.
