Jerky Tool Movement
Jerky Tool Movement
richardsalzman
Jerky Tool Movement
richardsalzman
I am new to CAM and machining.  I just finished converting a 2HP benchtop mill to CNC and have run 5 parts to date.  I am making these parts by watching an online CAM tutorial.  I was doing a dry run with part #6 (attached below) and noticed that during the 3D Adaptive tool path there was some jerking motion.  I reduced the no engagement feed rate from 90 ipm to 60 ipm and the jerking motion was reduced dramatically.  I could probably run the part with either the 90 or 60 imp no engagement feed rate however the jerking motion appears to make the mill shake a bit and I think I should try to avoid this.  At 60 imp, the jerking was quite minimal and may be just fine.
Are there other options within Fusion to smooth out these movements action?  I could probably adjust some of the acceleration parameters on my mill, but I thought I would see if it can be controlled via Fusion settings.
Thanks... Richard
Laurens-3DTechDraw
Hi Man,
If the whole mill is shaking it will have an effect on a lot of things, so if can be avoided I would do it.
I turned on the points in toolpath visibility and saw your adaptive had a lot of points which I think are causing your problems;
If this is causing problems is highly control and acceleration settings dependent. But it's a good place to start checking. To create less points there is the smoothing option in the passes tab;
Generally, it is set to 0.1*tolerance which I think it kind of useless, so I would go for the same as your tolerance.
So same toolpath with a lot fewer points. Try that and see if it's better.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
richardsalzman
Thanks for the rapid reply.  I will try changing the smoothing to .004 and see how it works.  Just curious, how do you turn on points in the toolpath?
I will also check with the Centroid CNC (the controller dudes) to see how I can adjust the acceleration parameters of the mill.
Thanks for you help!
richardsalzman
Hello again.  I did some further investigating.  I changed the mills acceleration parameter and it had no effect at all.  I reduced the no engagement feed rate to 45 ipm and it too had very little effect.  If I try increase the feed rate on the mill while running the gcode, the problem gets much worse.
I highlighted the sections of the toolpath on the attached image where the jerking is the worst.  Would it be a good idea for me to change the "High Feedrate Mode"?
Thanks... Richard
richardsalzman
Quick thought.  Here is a video of the toolpath.  Perhaps I am must being overly cautious.
Here is a video of this toolpath running at 100% federate (18 imp).
https://www.dropbox.com/s/pmyhbwsy8ql9lsz/20230217_111005.mp4?dl=0
If you think it looks good... I will run with it!
Thanks... Richard
richardsalzman
Thanks for all your help.  I ran the part and it ran quite well.  I had another problem but thanks for all your help with this issue.
All the best... Richard
