- Mute
- Permalink
- Report
Hi Group
i am tuning the bore of a component and i can't see clearly if the tool is running correctly on the 3d model so i decided to project a sketch so i can see the tool tip running on the sketch.
see the enclosed image regarding the projection.
the sketch plane is sliced through the center of the part, it is a tube with a radiused sloping internal edge then a through bore.
the blue biits are the selected 3d faces to project, the purple lines are the projections on the 2d plane but i am not getting the full 2d profile on the plane from the 3d shape? i roughly drew the expected results in red further down in the picture.
why do these surfaces not project as a 2d sketch on the plane?
the internal and external diameters project ok but these are straight so i am assuming faces with curves do not project??
please advise
