- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm machining small, acrylic, intraocular implants for work and am having issues with the paths that the CNC Mill is following. The mill is a MicroMill DSLS 3000, and I'm controlling it using Mach 3 on a 64-Bit, Windows 10 laptop.
I'm able to use the 3D operations to machine all of the contours just fine - and I'm quite impressed with how well they guide the 1/64" ball mill I'm using. I've been able to push it to a feed rate of 40 IPM! It's the 2D operations, however, that give me the issues.
Because of our patent situation, I can't go into a ton of detail about what the design looks like. But, the basic profile that I need to cut out using the 2D operations looks like a kidney bean. The implant, and, therefore, the profile, is symmetric and the toolpaths that Fusion generates reflect that. The issue I'm having is that the profile cut by the machine is lopsided, i.e., one side of the kidney bean is larger than the other. The width of the profile is 1.55 mm in Fusion, but, the profile cut by the machine goes from 1.45 mm to 1.65 mm. I did a brute-force fix of this by cutting out the center arcs, offsetting each end by the corresponding error, and then re-joining them with tangent arcs (see attached screenshot). This got the sizing consistent, but there are still numerous other issues with the shape of the profile, e.g., non-tangent edges at either end of the profile, and other jagged changes in direction.
Has anyone seen anything like this before?
Thank you!
Jay
