Internal threading on turning
jas.okon
jas.okon
Hello, I wanted to learn turning in Fusion 360 but I have found some problem.
I can't get a toolpath for internal threading. It only gives warning "no threads to machine."
I'm attaching my model, if someone could take a look I would be really grateful.
As far as i can tell, stock is not updating after drilling, maybe that's related somehow.
ivan.stanojevic
@jas.okon I was able to reproduce this. It seems strange but I suppressed the hole and the thread features and then I simply made a sketch, draw a circle with the same diameter and did a press-pull. And after, I selected this new face for my threading face and it worked.
Check the screencast:
http://autode.sk/2mzwDsF
@paul.clauss Could you please check on this?
Ivan Stanojevic
jas.okon
Bug confirmation and workaround in less than 2 hours, nice 😄
I tried your workaround and it worked! Thank you a lot.
I also narrowed it down to hole feature. If I made a thread in the press/pulled circle it works as well.
Thanks and I hope devs can fix this issue so fewer people are confused.
ivan.stanojevic
I agree, it is definitely an issue.
I hope it will be fixed soon.
Cheers
Ivan Stanojevic
paul.clauss
Hi @jas.okon @ivan.stanojevic
Thanks for posting! It looks like you are seeing an issue in which Fusion will not generate a inside threading operation with the geometry from your design.
I was able to see this issue occur in the design you attached to your initial post, but I was unable to in a new file. I have shown how I recreated your design and did not experience this issue in the screencast below - please let me know if I deviated from your modeling process or if you are able to recreate this behavior in a new file. As I have been unable to recreate this issue in a new file, I am unable to log it as a bug with our development team.
I can also confirm that redoing the hole feature in your file resolved this issue. It may have been that Fusion had some small data/feature related glitch while you were working on that particular feature - we apologize for any inconveniences this may have caused!
Paul Clauss
Product Support Specialist
ivan.stanojevic
@paul.clauss Good job!
Ivan Stanojevic
