Internal groove not working
Pillnoob
Pillnoob
I can not seem to get this internal groove to fully work. Please help.
Thanks in advance
randyT9V9C
With a ball grooving tool you should define the cutting point on center. In the tool library select the tool, select Setup, Compensation, Insert Center. You should also select your lead in and out geometries so the tool can bend the radii.
Pillnoob
We will give that a shot thanks!
Lonnie.Cady
@Pillnoob
What is wrong with the toolpath in the file you attached? Did not look too bad to me.  I always run full radius cutter to tip tangent since that is where I actually touch them off vs shifting them to the center of the cutter.
