Internal CAM kernel error
Hasse-Gällivare
Message 1 of 17
Hasse-Gällivare
What´s going on here?
I can´t change anything i Adaptiv 3 when i do i get a error
internal Cam kernel error
please help.
Replies (16)
Message 2 of 17
raven2DRN4
Same:
Yesterday I created a Cam. I can still load the file with valid tool path.
But if i click "Create tooplath" even without any changes I get this error.
It is also not possible to create any new tool path.
Here the error message:
Funktions-Flags aktiviert: milling-continue-rest-machining online-system-library setup-sheet-viewer tool-library-v4-release
Ungültig: Erstellung fehlgeschlagen
Fehler: Interner CAM-Kernel-Fehler. Senden Sie einen Bericht an den Support.
I tested it with multiple files - nearly the same for all.
All files using my Tool nr. 5 are broken. Other tool numbers are working.
Seems also different strategys are broken "3d pocket" as well as "2d contour".
Need urgent help!
Message 3 of 17
raven2DRN4
Update: Seems to be a bug in the tool library.
If i recreate exactly the same tool again, all Parameters the same - it is working.
But the tool which I use for years now can no longer be used in any CAM... Nor existing once and nor new once.
Message 4 of 17
Axelzzon
Same here.
Luckily i posted OP1 to the machine before i updated Fusion but now would be a good time to program OP2. 🙄
Debug message:
Enabled feature flags: hig-styled-qt online-system-library setup-sheet-viewer strategy-blend tool-library-v4-release
Invalidated: Generation failed
Debug: This operation depends on operation OP 1 Finger 2.
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\Mikael\AppData\Local\Temp\Fusion360CAM\1\operation64.ironjob
Debug: Writing jobfile to C:\Users\Mikael\AppData\Local\Temp\Fusion360CAM\1\operation64.hsm-job
Debug: Using CAM kernel from: C:\Users\Mikael\AppData\Local\Autodesk\webdeploy\production\644cb3fb363c9e2881e69c03ab808028604773bd\Applications\CAM360\camkernel.exe
Error: Internal CAM kernel error. Please report through your support channel.
Debug: Autodesk CAM Kernel 3.6.1 (6b8a5a00) x64 STABLE vs2017 6b8a5a001bae5ac4d0f40db9ac148f39dec8ed9b 2021/01/06 18:00
File "operation64.ironjob", line 33
SyntaxError: Non-UTF-8 code starting with '\xe4' in file operation64.ironjob on line 33, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Debug: Total processing time: 125 ms
Debug: Total elapsed time: 175 ms
Message 5 of 17
ci3jk4
For me it seems that every single tool in the tool library is now broken.
Fortunately editing the tool and changing even one letter in its name solves this for me.
Message 6 of 17
jedQB94J
Hi all,
Here is the work around:-)
Hope some software developer will take aaction on this.
Jacob
Message 7 of 17
mbl_busse
As far as I know it has to do with ne naming of the tools. The new Kernel seems to have a problem with toolnames wich have a umlaut like Ä Ö Ü in their names. See also https://forums.autodesk.com/t5/fusion-360-deutsch/fehler-im-cam-bei-neuer-version/m-p/10015391#M2318...
Message 8 of 17
Axelzzon
That totally worked for me too, had the swedish character "Ä" in the tool name!
Thanks, now OP2 will happen today! 😁
Message 9 of 17
seth.madore
Yep, this is a known bug that was discovered very late last week, we are working on a fix for it.
Seth Madore
Message 10 of 17
Hasse-Gällivare
Thanks alot you saved my day 🙂
Message 11 of 17
miechh
The same problem here. I have a Ø symbol in my tools to show diameter symbol. Done this for years, and after last update this suddenly isn't working anymore. Thanks for the work-around.
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 11 Professional (64bit)
Message 12 of 17
Richard.stubley
The CAM Kernel error should now be solved, the update has gone live, the build number is 2.0.9642
You should not have to remove any special characters now.
Pleas let us know if you are still experiencing the issue.
Richard Stubley
Product Manager - Fusion Mechanical Design
Message 13 of 17
BBK_CAD
All files will not generate any tool paths now. Get this message with every file, even ones that worked fine for years if I try to re-generate any toolpaths they get corrupted.
Here is message:
Feature flags: adaptive-turn-roughing contour2D-select-faces hig-styled-qt old-turning-profile-strategy setup-sheet-configurations setup-sheet-viewer spun-profile-v2 strategy-blend
Debug: Writing ironjob to C:\Users\smirch\AppData\Local\Temp\Fusion360CAM\17364-2\operation3.ironjob
Debug: Writing jobfile to C:\Users\smirch\AppData\Local\Temp\Fusion360CAM\17364-2\operation3.hsm-job
Debug: Using CAM kernel from: C:\Users\smirch\AppData\Local\Autodesk\webdeploy\production\65899d0f0113f775e86f30ece2eeaf89fc855cb7\Applications\CAM360\camkernel.exe
Debug:
Debug: Total processing time: 31 ms
Debug: Total elapsed time: 133 ms
Message 14 of 17
seth.madore
@BBK_CAD the post you are replying to is over a year old, it's likely you are experiencing a different issue from the OP. Are you on Windows 7? There is a known issue, give THIS THREAD a read
Seth Madore
Message 15 of 17
jedQB94J
I know this is a old thread, but I can't reproduce the calculation. It works fine for me.
Win10 on a laptop
Message 16 of 17
BBK_CAD
Thanks, I"ll give that dll a shot, hopefully that's it.
Message 17 of 17
BBK_CAD
That worked, thank you much!!
