INSPECT SURFACE ERROR
designcastudios
designcastudios
Community Visitor
Community Visitor
Hey guys. I am getting a yellow error sign after importing inspect results DPRNT file back into fusion.. Everything still generates and seems to work good I want to make sure this error is not throwing off results and how to get rig of it. I used my cad body in set up and also tried from solid in set up  I keep getting the same error.... I also wanted to ask a question on the results.. My Z plane is the one I am inspecting... where does the nominal -.551" number come from if this is my ZERO in set up shouldn't that number be zero in the results and take deltas off that?
Tomek.G
Hi @designcastudios,
Depending on the driver and configuration, the result file is not overwritten, but additional lines are added to the existing file. In this case the file will contain multiple START and END marks.
Be aware that only results from the last pair of START and END markers will be taken.
Document and model identifiers are stored in the result file. If the model or operations are updated after the NC program has been generated, the identifiers will not match and a warning message will be displayed.
You must ensure that these changes do not affect previously generated points.
Tomek.G
Sr. Technical Consultant
