incremental Feed height
Danvil9226
Danvil9226
I'm sure there is a simple solution here..
When cutting deep slots or even profiles, i don't always want to machine in both directions or keep the tool down.
Is there a way to adjust the feed height so its working off the last cut.
So instead of rapiding out, and feeding all the way down. It rapids out and rapids down to within .03" of the last depth of cut?
seth.madore
You can have it rapid out and then back down, but you can't have it retract based off it's last cutting Z height. Set your Feed Height to "disabled".
Seth Madore
