Incorrect H # in g code
Message 1 of 28
When I write up a program and post it and transfer it to my tormach mill, the H in the top of the g code is always H1 . I have my tool live matching the tool library on the machine,  if I edit the g code and enter the tool number in place of the 1 in the g code, it works fine. If someone could help me out I'd certainly appreciate it.
Replies (27)
Message 2 of 28
amcfarlen
I was just coming here to look for something similar.
As I was attempting to run some code and had a tool crash into the table and averted 2 more by running at what I presume was a safe work offset as a sanity check.
I'm using the Mach3 post and noticed that no matter what tool I use (multiple in the same job set up) it will put out code like this fore instance.
M5
M9
T5 M6
S14300 M3
G54
M9
G0 X-22.789 Y0.319
G43 Z15. H0
Is this correct, or should it output H* as the tool number as well in order to grab the offsets from Mach3's tool tables?
Allen R. McFarlen
Barron River Guitars & Ukuleles
Cairns, Australia
27" iMac | 3.1 Ghz Intel Core i5 | 20 Gb ram | OSX Sierra 10.12.6
Message 3 of 28
HughesTooling
One thing to check in the tool manager is that the number and the length offset match.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 28
tmodcustoms
I read that somewhere, I was thinking that was the problem however I am sure the tool tablet in the library and the one in the machine are matching.. ks there something else that I could be missing there. If I try to run the program without changing the g code manually the tool length display turns read and reads 0.0000 and h refers to the tool length offset, I just don't know what else I could be missing.
Message 5 of 28
HughesTooling
Can you export your program and attach to this thread. To export click on the File menu pick export and save as an f3d file.
Mark
Mark Hughes
Message 6 of 28
Laurens-3DTechDraw
Question for all that are having this problem what post processor are you using?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 7 of 28
I'll export it in about half hour, I'll be at the shop. I'm using the most recent post from tirmach, not the generic mach 3, I'll see what it is called exactly when I get there. Its for a tormach 1100.
Message 8 of 28
Laurens-3DTechDraw
The latest version on the Tormach site seems to work correctly.
Laurens Wijnschenk
3DTechDraw
Message 9 of 28
tmodcustoms
Unable to attach, , on example, but it happens in every program I post, Im using the post from tormach. Im assuming there is no problem with the post processor, rather it's some box I haven't checked or the likes.. thanks !
Message 10 of 28
tmodcustoms
http://a360.co/1YIKJ3Z
heres a link, wouldnt let me attach the file here.
Message 11 of 28
HughesTooling
It's like I said you don't have the tool length offset set in the tool library. Here's a screen shot of your tool, the length offset is 1.
Mark
Mark Hughes
Message 12 of 28
Awesome, thanks Mark! The length offset in the box there and the diameter offset should match the diameter in the top box and the overall length in the bottom box , under the cuter tab correct? (Which match the numbers I'm the tormach tool library on the machine in path pilot )
Message 13 of 28
Message 14 of 28
HughesTooling
Normally you'd have the same number in all 3 boxes so in the image I posted of your tool, set them all to 29.
Mark
Edit. The numbers are to call the offset from the tool library in your control, they are not the sizes.
Mark Hughes
Message 15 of 28
All there boxes set as the tool number,  got it. Like this correct?
Message 16 of 28
HughesTooling
Yes, now when you post you should get a call for T29 and H29 you just have to make sure you've set the diameter and touched off the length for the tool in the library on your machine.
Mark.
Mark Hughes
Message 17 of 28
Awesome,  thank you very much my friend,  I really appreciate your help!
Message 18 of 28
amcfarlen
I just checked my tool library and saw that the tool lenght offset all said 0, so I changed them to the appropriate numbers. Then regenerated the post. But still there isn't any change to the output. They still say H0.
Am I missing something?
(1)
(T5 D=6. CR=0. - ZMIN=-5.5 - FLAT END MILL)
(T12 D=8. CR=4. - ZMIN=-1.646 - BALL END MILL)
G90 G94 G91.1 G40 G49 G17
G21
(PARALLEL1)
M5
M9
T12 M6
S16000 M3
G54
M9
G0 X22.995 Y296.8
G43 Z15. H0
Allen R. McFarlen
Cairns, Australia
Message 19 of 28
Haha, same here. I regenerated the tool paths and hit post, same thing.
Message 20 of 28
HughesTooling
Did you update the tool library in the design as well. Once the tool is used in a design it is not linked to your main libraries. The Document libraries are at the top of the tool manager.
Mark
Mark Hughes
