In process stock and completed areas are the same color. How can I change
tgford58
tgford58
This has been an ongoing problem but while developing my CAM strategy the remaining stock color and the areas that are already completed are the same dark green.  It makes it hard to distinguish the areas that I've cleared vs the areas left to clear.   I've searched the forums and worked on this off and on for quite a while and can't find a fix.
a.laasW8M6T
In process stock is just a rough visual aid to help you see the what the toolpath is doing , if you want to see remaining stock you can simulate the toolpaths with the stock mode set to Comparison.
It would totally be handy to see the comparison mode for the in process stock but it think the computation times would be very high leading to more frustration than its worth.
Andrew Laas
Senior Machinist, Scott Automation
