Importing external model revision without loosing CAM setups
RG_Productions
RG_Productions
Wondering how best to import new model revision from a client without loosing CAM setups.
I have found if I use Import New Version all my setup are lost.
So currently I have been uploading the new version and inserting it into the pervious rev, so at least I still have a reference for the 2D and boundary selections. TIA!
Richard
a.laasW8M6T
You can do it using teams with any cad but I believe it will only work with .sldprt or .ipt files (solidworks and inventor).
Its a bit of a process to do
Check this out
https://www.autodesk.com/campaigns/fusion-360/anycad
Andrew Laas
Senior Machinist, Scott Automation
daniel_lyall
What file exstension?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
HughesTooling
What I do is import the model into another design and create the CAM in that file. So upload your model, import into a second design creating in effect an assemble and create the CAM setups in the assembly design. If you then upload a new version of your original design the assemble can be updated without losing your CAM.
This does not help with your existing designs though but your could insert them into a new design, copy the CAM setups into the assembly design and fix the lost references in the setups and ops.
Mark
Mark Hughes
Owner, Hughes Tooling
RG_Productions
Thanks @a.laasW8M6T this is exactly the solution I was looking for!
Thanks @HughesTooling this is pretty much what I'm currently doing, thought that there must be a better way. I had been CAMing up assembly files until only 18 months ago when I was shown the derive function!
RG_Productions
Here's the link to the release video, which due to the name I thought wasn't relevant to me haha
https://www.youtube.com/watch?v=DnY0QLHsQiM&ab_channel=AutodeskFusion360
