iMac needs to connect to older machines that use RS232 inputs
JonSchaeffer
Message 1 of 8
JonSchaeffer
Anyone use an Apple computer to up load NC file to older Lathe that uses RS232 inputs?
Can I go and get cables that go from iMac USB and connect to the RS232 on the machine?
www.genesisprecisionaz.com
[email protected]
Replies (7)
Message 2 of 8
RandyKopf
@JonSchaeffer
I don't have a MAC but did have the same problem with a PC that had no serial ports.
Radio shack has a USB to RS232 cable that worked. My PC added it as a COM4 and I was good to go.
The cable did not say it was for PC or for MAC so there is no reason it would not work.
The Gigaware cable I bought was a USB to DB9 pin Serial
Bestbuy has them and states they are compatable with both PC and MAC
http://www.bestbuy.com/site/searchpage.jsp?id=pcat17071&st=usb+to+serial
There are also cables that will convert from 9pin to 25pin if you need that.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=432216
Hope this helps!
Randy Kopf
http://desktopartisan.blogspot.com/
If my post is helpful, press the LIKE Button If it resolves your issue, press Accept as Solution! Have a great day!
Message 3 of 8
JonSchaeffer
@RandyKopf cool thank you.
Did you need to use a certain software to set up the bod rates and Parity and that stuff?
[email protected]
Message 4 of 8
RandyKopf
@JonSchaeffer
I happen to run a copy of Cimco Edit. It lets me setup Baud Rate, Data Bits Stop Bits etc... Protocol etc.
There was discussion a couple weeks back on this subject in this post.
https://forums.autodesk.com/t5/computer-aided-machining-cam/dnc/m-p/6637017#M18633
Mark with Hughes Tooling made a suggestion to use Heidenheim's free communication tool with the link to that software in the post I just linked.
Randy Kopf
Message 5 of 8
xander.luciano
He's on a mac though, so most DNC software is going to be a windows program.
Surprisingly, this has come up a lot recently and at one point I had thought of programming a simple multi-platform DNC program so that Mac users could transfer files also. Seeing as there is still clear demand for such software, I think I might actually develop one.
Good to know there's a need for one!
Best,
Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Message 6 of 8
RandyKopf
Back in the day in we would script an open port... Set comm rates and protocols and pipe a file to that port. Not sure Mac is that smart? that was on https://en.wikipedia.org/wiki/MicroVAX but I'm sure you'll figure it out just saying.
Randy Kopf
Message 7 of 8
xander.luciano
Haha exactly! For a 1 one communication protocol that's all you need!
I have no issues doing that on windows as I can hook into the .NET serial port library. My only concern would be that the mac would restrict access to the COM port. I gotta look into OS X a bit more to figure it out.
Xander Luciano
Message 8 of 8
JonSchaeffer
Well I am on my way to an electronics store. To get a USB to Serial Port.
And I down loaded a trial version of Easy DNC I will give an update to how it works out...
[email protected]
