If 'relative size tube' chosen in setup, WCS is OFF CENTER for no obvious reasons
MultiMasz
MultiMasz
Its significant, but its hard to see, if you wont check stock size.
See screenshots
engineguy
@MultiMasz
Odd, without seeing your file it is not easy to see what has gone wrong, it seems to work OK here, see images below and attached file. In your Images there is a Sketch, what is the reason for it and does it align with the Part ??
Also, what Build are you on, there were some issues like this a while back but it seems to be OK now 🙂 I have Build 2.0.14569
MultiMasz
I have the same, up to date version. Selecting axis helps, but now should be mandatory or else WCS just lands somewhere, near enough to be easly missed.
DarthBane55
On your last picture, the stock looks off center to the part.  Something might have moved somewhere, can you try to repick the part as the model to machine and see if the stock falls in place?
brekmiller
See my reply in this thread:  https://forums.autodesk.com/t5/fusion-360-manufacture/cylinder-stock-gt-fusion-comes-up-with-weird-m...
It is bug CAM-40426, which was fixed yesterday.  You will get the fix in an upcoming release.
Brek Miller
Software Engineer
