I’m getting a unexpected word error in G code
thedoncutta
Message 1 of 10
thedoncutta
Getting an unexpected word error in g code in planet cnc on export
Replies (9)
Message 2 of 10
seth.madore
More info is going to be needed. Do you have a screenshot, nc file, F3D file perhaps? Are you getting this error at the machine, or when posting the code in Fusion?
Seth Madore
Message 3 of 10
thedoncutta
At the machine I will post a screenshot shortly after church
Message 4 of 10
thedoncutta
I’m getting this error at the machine
Message 5 of 10
seth.madore
Which post processor are you using? It looks like it's failing on a drill cycle, is that correct?
Seth Madore
Message 6 of 10
thedoncutta
Not sure!!! This is the processor someone found for me but it’s not the correct one I guess… 
Message 7 of 10
seth.madore
Can you share the file that has the toolpaths that are creating this error? Do you know what your machine needs to see for drilling cycles? (do you have a programming manual for your machine)
Seth Madore
Message 8 of 10
a.laasW8M6T
Hi Seth
Its actually the smoothing mode, excerpt from planet cnc manual:
G64 - Blend Enable
Usage: G64 <P> <Q> - P (optional) = tolerance
In blend mode sharp corners will be rounded and the machine may never reach the programmed
point before a direction change. Optional tolerance can be set.
Parameters:
#<_blendmode> - (R) current blend mode
#<_blend_tol> - (R) current blend tolerance
Not sure why the machine doesnt like the Q value but i dont think its needed
This can be changed in the NC Program dialog:
Change it from G64 with PQ, to G64 with P
Andrew Laas
Senior Machinist, Scott Automation
Message 9 of 10
thedoncutta
Thanks I will try this
Message 10 of 10
thedoncutta
Thanks I will try this.
