Hurco 5 axis 3+2
Hurco 5 axis 3+2
gianni.martino
Hurco 5 axis 3+2
gianni.martino
Greetings. My problem is the following.
I have a Hurco VMX24t on which an LCM model (BSCMM200) rotary-tilting table is mounted.
The settings are:
(B axis) Action rotates around Y axis (excursion 0°, -90°)
(A axis) spindle rotates around the X axis. (excursion 0°, 360°).
The attached photo shows the position A=0° B=0°
The post process file used is the one downloaded from the Hurco r44084.cps cloud with rotary axis settings. (see attached photo).
The kinematics are incorrect. The graphics of the machine do not follow the graphics of Fusion.
Where am I doing wrong?
Thanks for the attention.
Greetings.
scottmoyse
Have you tried building a machine configuration in the Fusion 360 UI instead of using the config in the post?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
gianni.martino
Greetings. I solved it by setting the machine kinematics in the Fusion 360 configuration. Now I have problems with the line centers. I have some overages following the transformation of the plans. I can't match the virtual WCS with the machine's relay WCS. I'm working to create a fusion machine model identical to my VMX with a tilting rotary table kit. Thanks for your suggestion to solve with vectors.
scottmoyse
If you search for "Hurco VMX" on this page you will find a heap of options, which you can probably start with or use directly.
https://cam.autodesk.com/machineslist
Scott Moyse
