How would you machine this part? 3 axis router
Cave_Master
Cave_Master
How would you machine this part?  Specifically the top surface and the pocket on the top surface.  I have a 3 axis router.
ChristopherMarion
Hi @Cave_Master
It looks as if you've got a pretty good handle on this.
Personally, I like using ball nose tools when milling contoured surfaces.  I feel like they give me a better, consistent surface finish and consistent stock removal.  Obviously, to get the sharp corner in the pocket, you will need to use a flat endmill or a really small ball nose tool.
If you can get away with leaving a small fillet at the bottom, I'd go with the ball nose route.  You can do multiple offsets with the pencil strategy to work your way in from the remaining material.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Ketherton21
3d parallel/2d trace
