How to set a specific TOOL COMPENSATION POINT?
JonSchaeffer
Message 1 of 13
JonSchaeffer
I am looking to have this feature added to the lathe side please.
I am wondering if there is a way to set a tool compensation points other than just the 4 options we have?
TIP CENTER
TIP
TIP CENTER
TIP TANGENT
I have many parts that the tool position is crucial for centerline and tool holders vary with where the actual center line of the insert truly is... but if we have this option to create a tool compensation point we can have more first part buy offs, less manual data offsets and risk of a wrong number being entered, and a possible crash from happening.
Second question sort of related,
The 1st screen shot for some reason has the insert not even on the tool body.
I have defined the insert and tool body but not sure why this looks like this?
www.genesisprecisionaz.com
[email protected]
Replies (12)
Message 2 of 13
akash.kamoolkar
@JonSchaeffer we have a ticket to add a custom compensation point, however there is no ETA on when it will be done. As to the strange tool model can you attach your file here so I can get someone on the tool library team take a look?
Akash Kamoolkar
Software Development Manager
Message 3 of 13
JonSchaeffer
That is great news!
Anxiously waiting for these updates.
Also I could not find a way to export the tool in question.
I am not allowed to share the whole file NDA reasons.
Is there a way to share just the tool?
Is there someone you can get me in touch with that I can offer help with the lathe updates?
We do a lot of complex turning here and we have a lot of suggestions and needs for the lathe portion of Fusion 360.
I am a Fusion 360 "Early Adopter" and have had quite a few ideas added to Fusion 360 in the past when there was an Idea Station.
[email protected]
Message 4 of 13
akash.kamoolkar
@JonSchaeffer if you right click on a tool library you will see an option to export it. with regards to turning feedback I will let our turning product manager know.
Akash Kamoolkar
Message 5 of 13
JonSchaeffer
I tried that and I get a not supported file type.
[email protected]
Message 6 of 13
akash.kamoolkar
@JonSchaeffer strange. i was able to do it. you can try to export it as a .json file.
Akash Kamoolkar
Message 7 of 13
JonSchaeffer
Still not working, even as a .json
Got another way?
[email protected]
Message 8 of 13
seth.madore
To clarify; you're able to export the tool, but not share it to the forum, is that right? Or do I have it the other way around..
Seth Madore
Message 9 of 13
seth.madore
If so, just dump it into a ZIP folder and attach that here instead
Seth Madore
Message 10 of 13
JonSchaeffer
Right I can export it but the file type is not allowed.
I think I tried a zip file originally, but I will try again.
[email protected]
Message 11 of 13
DarthBane55
You could create an empty lathe CAM file and copy the tool in it, then export the usual Fusion file, might be simpler.
Message 12 of 13
JonSchaeffer
OK I zipped it
[email protected]
Message 13 of 13
akash.kamoolkar
@JonSchaeffer I'm seeing the tool issue in the production version but not in my dev version so it's likely that it has been fixed already.
Akash Kamoolkar
