- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Just wondering if someone might be able to point me in the right direction on how to cut the flat surfaces on either inner side of this part ... Because they are bolt surfaces, they need to be as flat as possible...
We are using a HAAS VF3 with a 4th Axis Table, but I still can't seem to figure out a way to cut the flats, or what type of tool I might need to get this done effectively. (Be kind, I am new to this game)
Between that and the radius under on each end - I need a better idea on how to do that also.
(I am trying to get a pencil operation to make a pass, is that close ???)
Because of the length I assume you need special tooling to reach, and at present I only have a 150mm 12mm End Mill, but I can't rotate it and cut those surfaces neatly, so I must be doing something wrong ...
Any help would be greatly appreciated, thanks in advance,
Aaron.
