How to import / add to an existing project?
SimonPlatten
SimonPlatten
Is it possible to import an existing file / body into another project ?  If yes, how?
I have build an adapter that I want to use as a component in another project.
Thank you @SimonPlatten for sharing your problem with the community.
Yes, you can import the design into another design and I have attached the link for further process.
Link https://www.youtube.com/watch?v=wHsLnGWI1lg
Hope the above information helps you!
Bhavesh Raghwani
TrippyLighting
Yes, simply right-click on the design of that adapter in the data panel in Fusion 360 and select "insert into current design" from the menu.
You might want to consider breaking the link to that inserted design after insertion.
