How to generate Mach3 file?
sandijs_volks
Message 1 of 11
sandijs_volks
Milling machine: CNCEST (China) Fetcoi CNC 6090.
Soft:Mach3
I also have one question regarding the 4 rotary axis.
I am new to Fucion360. Everything looks good when simulating the model, but when trying to
generate *.tap file for mach3 I get an error.
Replies (10)
Message 2 of 11
seth.madore
You're using the Mach3 "turning" post processor, which is for lathes. You want to be using the Mach 3 "milling" post processor. Additionally, you'll want to make sure you've enabled the 4th axis in the Configuration section of the post dialog.
Seth Madore
Message 3 of 11
sandijs_volks
thanks for the reply
Message 4 of 11
sandijs_volks
I corrected this. Now another error appeared.
Error: Direction is not supported for machine configuration.
Error in operation: '6.5mm Parallel2'
Error at line: 804 (mach3mill.cps)
Failed while processing onOpen().
Message 5 of 11
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 6 of 11
sandijs_volks
galva.f3d
Message 7 of 11
seth.madore
You have your Setup created incorrectly, you want your X axis running along the axis of the shaft, not the Z axis.
Seth Madore
Message 8 of 11
sandijs_volks
I changed the x axis, but something is still wrong.
Message 9 of 11
seth.madore
Hmm, I'm not getting that error:
Seth Madore
Message 10 of 11
sandijs_volks
Message 11 of 11
sandijs_volks
Thanks seth-madore, now it works correctly!
