How to drill hole on a side of part 90 degrees
Message 1 of 15
Pls could some one to tell me of how to drill hole not only from top side of some rectangular part, but also from left and right, front and back side...!?
Replies (14)
Message 2 of 15
seth.madore
Do you have a 4 or 5 axis machine? If so, make one Setup and use Tool Orientation.
If working with a 3 axis machine, you will need to make one Setup for each part orientation, using "Select Z and X axis" to align the Setup to the part.
Seth Madore
Message 3 of 15
I have haas fv4ss,
What could you advice for me in this case!?
Message 4 of 15
seth.madore
A VF4SS is machine size, that does not tell me if you have a rotary axis on the machine as well. Is that the case?
Seth Madore
Message 5 of 15
As I know haas vf4ss has only three axis and it dont have any rotations, i think, this is my case...
Message 6 of 15
seth.madore
By "Rotary", I was inquiring about the presence of a 4th axis unit such as a an HRT-210
Since you don't have one of those on your machine, you will need to create a Setup for each side of the part you wish to work on. If you are new to Fusion, and CAM in general, I strongly suggest working through the tutorials and the YouTube content that we put out
Seth Madore
Message 7 of 15
Can I create this new setup in this project that I have from the begining or I need to create the new!?
Message 8 of 15
I tried to find some samples in which described cases when you need to work with different sides of rectangular, but I didnt find it...
Message 9 of 15
I changed working side of my part, but Fusion don`t see that hole that is situated on curved surface...
Message 10 of 15
seth.madore
Do you have a file that you can share?
Right click on the file in the Data Panel and select "Share Public Link". Copy the link and paste it here. If it's a sensitive file, you can PM me the link if you prefer.
Or;
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply if the file contains linked components, either break the links or put the .f3z file in a .zip folder and attach that.
Seth Madore
Message 11 of 15
I atached it here to my message...
Message 12 of 15
Ok, I figured out how to change orientation of axis to do side drill, but how to do that in case if I want to change orientation of axis but not orientation of stock, samples attached...
Message 13 of 15
seth.madore
Generic stock will align itself to the selected Z axis and won't always display correctly. I've learned to live with it, as it's the code I'm after, and not entirely the simulation. If you have your WCS set to a point on the part itself, there shouldn't be an issue. If you have it set to a stock point, then there's a strong likelihood of an issue arising.
The only way to have the stock not change alignment would be to model it out and select that in your Stock definition.
Seth Madore
Message 14 of 15
Could you check in my project, is it problem in my case or not!?
Also what command could you advice to create this chanel!?
Message 15 of 15
seth.madore
Yes, that is what is happening in your file. To avoid this graphical display, you would need to create an actual solid model of your stock. We do have work underway to better streamline that process.
To machine that slot, I'd likely use an endmill (smaller than the slot) and use a 2D Contour. The presence of the hole breaking through the slot would likely necessitate an additional sketch line to bridge over that:
Seth Madore
