How To Add Line Numbers at Tool Changes?
utekcnc
Message 1 of 11
utekcnc
On our other CAM system it's puts a line number at every tool change.   We don't use numbers except for that.   For example right before a M6T2 it will place N2000.    We use these for restarting.   I'm using the generic Fanuc post.  Is there anyway to do this?  Or can I add the code before I post process with Manual NC?   I can't seem to get it to work any which way.   Thank you.
Replies (10)
Message 2 of 11
randyT9V9C
I implemented this in one of my posts using a couple user parameters in my post processor. Looking at the code tonight it could be done without the numberOperations switch and simply turn it on if showSequenceNumbers == false. Maybe this will get you pointed in the right direction.
  if (hasParameter("operation-comment")) {
    var comment = getParameter("operation-comment");
    if (comment && properties.numberOperations && properties.showSequenceNumbers == false) {
      writeWords2("N" + (sequenceNumber % 10000), ";(" + comment +")");
      sequenceNumber += properties.sequenceNumberIncrement;
    } else if (comment) {
        writeComment(comment);
Message 3 of 11
utekcnc
Ok, I'll take a look.  I've never messed with things inside the post, so hope I don't mess something up.
Message 4 of 11
engineguy
@utekcnc
Make sure you make a copy of your Post and save it somewhere on your computer before making any alterations, that way you can easily paste it back into your Post library and be back to where you started from 🙂
Regards
Rob
Message 5 of 11
utekcnc
Well, I looked at that and couldn't make heads or tails of it.   I'll have to study it sometime I guess.
Message 6 of 11
randyT9V9C
Which Fanuc post are you using?
Message 7 of 11
utekcnc
FANUC/fanuc
Message 8 of 11
randyT9V9C
Copy the Fanuc post to your personal/local posts folder and change line 1117 to this:
    if (!properties.showSequenceNumbers) {
      writeBlock("N" + (sequenceNumber % 10000), "T" + toolFormat.format(tool.number), mFormat.format(6));
    } else {
        writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
This will only number the tool changes when you turn off sequence numbers. You can also change line 44 to showSequenceNumbers: false so your newly modified post will default to your desired behavior.
See the attached modified Fanuc post.
Message 9 of 11
utekcnc
Thank you,  I will take a look in a day or two and see if I can do this per your instructions.
Message 10 of 11
utekcnc
This worked in the part that it adds numbers at each tool change.   Is there a way however that the N number would match the tool number?   For example, If I'm using tool 9 it would say N9 or N9000?
Message 11 of 11
randyT9V9C
Change the statement to use tool.number for your block number on the if statement starting on line 1117:
      writeBlock("N" + (tool.number), "T" + toolFormat.format(tool.number), mFormat.format(6));
    } else {
