How much is my tolerance?
FrodoLoggins
Advisor Advisor
Message 1 of 15
FrodoLoggins
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Replies (14)
Message 2 of 15
seth.madore
Well...that's a good question. I'm updating my Mac as we speak to see if this occurs here as well. I bet it will..
-EDIT-
Well, sorta does it. However, once I drag out the window size a bit it goes away. Can you confirm that this issue remains regardless of window size?
Seth Madore
Message 3 of 15
mattdlr89
I've never used the slot but I see the same as I shrink the window width down. It's because "Tangential Fragment Extension Distance" is so long and all the boxes are aligned tot he longest title. Is this a change with the new update?
Make the window wider and you'll be able to read it for now until they fix the UI.
Message 4 of 15
mattdlr89
That's on windows ^
Message 5 of 15
FrodoLoggins
I can't drag to resize the window.
Message 6 of 15
seth.madore
When they're not docked. Dock them first
Seth Madore
Message 7 of 15
Laurens-3DTechDraw
Honestly, I'm confused why that happens to you on Windows as well. Seems to work fine here.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 8 of 15
mattdlr89
@Laurens-3DTechDraw
Try it with the slot machining strategy or perhaps engrave too. I had a quick check and it behaves properly on all the 2D strategies apart from slot and engrave. I'm not going to bother checking the 3D toolpaths but perhaps it would be wise for the Development team to check
Message 9 of 15
NickErmis
I accidentally undocked my browser ... is there an easy way to redock it???  lol
Message 10 of 15
mathew.hutton
Hi @NickErmis
If you click and drag the toolpath panel to the right hand side of your screen, you'll see a green line along the side of the screen. if you release your mouse button at the point where you see this green line it will dock your browser again. See attached
Cheers
Mat
Mathew Hutton
Manufacturing Specialist
Message 11 of 15
NickErmis
Awesome!! Thanks, I figured it was something simple.
Message 12 of 15
Laurens-3DTechDraw
Engrave works fine for me.
Slot though😑
Laurens Wijnschenk
3DTechDraw
Message 13 of 15
mattdlr89
It happens on a few for me. Slot is the worse because it has the longest description for one of the boxes. The error is the boxes shortening instead of the text. I can see this on engrave but you have to make the box smaller than you'd need.
It also happens on the Geometry tab for 2D Chamfer.
Anyway hopefully it'll get corrected in the next update...
Message 14 of 15
seth.madore
Yeah, this is all recorded in the ticket and the team is working on it.
Also, you don't actually need to dock it to resize. On the bottom right of the operation box is a grab handle you can click and drag with the mouse.
Seth Madore
Message 15 of 15
Laurens-3DTechDraw
Love that my operation box now will never be the correct size anymore as you keep resizing it now.
Laurens Wijnschenk
3DTechDraw
