How do you save post processor settings?
jenmach
jenmach
Is there a way to save post processor settings that were altered by using the drop downs in the post process/NC program dialog box?  Currently non-default settings are highlighted but not updated in the post processor cps file itself.  Do these have to be changed manually in the cps or can they be saved?
engineguy
@jenmach
The idea of having the "Properties" is so the User has some control over certain functions so, no, they do not change the Post Processor permanently every time. That would be a very bad idea IMHO.
If you want some things to be the exact same every time then yes, you would need to Edit the actual Post Processor and then every time that PP is used the settings would be set the same.
