@engineguy wrote:
@rhetths
Workflow, unless you are doing this on a 4 axis CNC then you should use the Flat Models before you put the bend in, as there is nothing in the Timeline to show the bending where it could be edited I did the next best thing and just created two Flat versions and placed them in two individual Files, you need to go right back to where you created the Sketch and extruded it for the shape of the brackets, just do them as Flat plate and if you then want to see a version of the actual bent Model use the "Sheet Metal" function to create a Model you can see the shape of.
The Model is really just "cosmetic" for you to look at or maybe send an image to a Customer of what the finished item will look like, if you need to you can create a Drawing with dimensions etc, etc, etc 🙂 🙂
Meantime if you are struggling to get the job cut try the attached files, one is for machining and the other is the "Cosmetic" Model one.
I will leave you to do all the Chamfering on the Manufacturing version, TBH I just forgot to put them back on 🙂 🙂
Cosmetic Model
Flat for Machining
I was repeatedly advised to design in final form, therefore i did not start by making a flat piece of plate then fold it. Did i do it wrong? I realise there are some circumstances where the program forces you to start with flat plate and fold it, but this didn't seem like one of those.
The files you created didn't just delete the chamfers, the logo 'RHS' also moved out of position.
Are you saying, that, because you couldn't unfold both at the same time, you put them in separate files, unfolded them, then put them back into one file?
I am aware that the sketch(s) for the logo 'RHS' are not present. Is that causing issues? I don't understand the significance of sketches, or at least, why they should be a fusion show stopper, since, when there is a solid model in the program, fusion obviously has all the dimensional data it needs?
Are many or most or all fusion users sometimes thrashing around trying to make things work by whatever workaround they can, or is there actual logic to the program that means users can obtain a seamless experience?
Previously, i typically exported DXF's of flat patterned or unfolded (so many workarounds i forget) components into files for manufacturing. Considering you lost the chamfers, i wonder if you used that workaround?
Often the program shows me that it can do the things i want it to do, such as in this instance quickly and simply unfolding a component i created in final form, which i could then seemingly toolpath, but due to oddities the program stops the outcome from being achieved.
