How do I countersink a hole with a modeled countersink using an 82° countersink?
simspacetn
simspacetn
I'm trying to counter sink a hole that has a modeled countersink, with an 82° countersink using a simple drill operation. It will not work. I keep getting this error:
Error: The current tool or holder cannot be used with this thickness and tolerance.
Either the tool radius or a holder component length is too small.
It is a .511" diameter, 82º countersink. I am using a 1/2" countersink with a flute length of 0.320". I selected the correct hole face (see attached image).
I cannot figure out what the problem is..
Thanks!
simspacetn
Never mind! When I entered the tip diameter, I entered 0.4" instead of 0.04" 😳
Problem solved.
