How do I change tapping cycle in postprocessor
I have this right handed tapping cycle from Fusion 360:
O1000
(T48 D=10. CR=0. - RIGHT HAND TAP)
N10 G90 G94 G17 G49 G40 G80
N15 G21
N20 G28 G91 Z0.
N25 G90
(DRILL3)
N30 T48 M06
N35 S100 M03
N40 G54
N45 M01
N50 M44
N55 G00 C90.
N60 M43
N65 M01
N70 M08
N75 G00 X-21.886 Y132.306
N80 G43 Z70. H48
N85 G01 F6500.
N90 G00 Z55.
N95 M29 S100
N100 G98 G84 X-21.886 Y132.306 Z-20.814 R-2.814 P0 F150.
N105 X94.689 Y132.307
N110 G80
N115 G01 Z70. F6500.
N120 M09
N125 G28 G91 Z0.
N130 G90
N135 G49
N140 M01
N145 M44
N150 G00 C0.
N155 M43
N160 M01
N165 G28 G91 X0. Y0.
N170 G90
N175 M30
But it doesnt work in my machine because of the M29 code.
The one we have from Mastercam does work, but how do I change the postprocessor from Fusion 360 to read out similar code to the one from Mastercam?
Mastercam:
(TAPP)
(DATE=DD-MM-YY - 22-02-21 TIME=HH:MM - 07:39)
(MCX FILE - T)
(NC FILE - C:\USERS\TBJOR\DOCUMENTS\MY MASTERCAM 2021\MASTERCAM\MILL\NC\TAPP.NC)
(MATERIAL - ALUMINUM MM - 2024)
( T11 | 12 RIGHT-HANDED TAP | H11 )
G21
G0 G17 G40 G49 G80 G90
T11 M6
G0 G90 G54
(START TILT/ROTATE)
M01
M44
G90
C90.
M43
(STOPP TILT/ROTATE)
M8
G0 G90 G54 X0. Y0. S100 M3
G43 H11 Z50.
G98 G84 Z-50. R10. F175.
G80
M9
M5
G91 G28 Z0.
G91 G28 X0. Y0.
(START TILT/ROTATE)
M01
M44
G90
C0.
M43
(STOPP TILT/ROTATE)
M43
M99
boopathi.sivakumar
Hi@Anonymous
While post processing choose Use rigid tapping as No, this should output without M29
Boopathi Sivakumar
Principal Technology Consultant
