horse power cnc machine
conjured2018
conjured2018
HI, I am getting a new machine. I cut hardwood, plywood and make furniture. I see many cnc machines have 3-4 hp spindles. I believe this to be underpowered. any thoughts?
I am gettting a industrial strength machine from Laguna tools, or industrial cnc.  Thank you JR
seth.madore
Horsepower, in many respects, is only going to be as good as your workholding. There's little value in a massive spindle if your vacuum table or clamps aren't up to the task.
While I don't have a huge amount of experience with wood routers, I do know that a lot of people use 2.25 HP router spindles in their semi-industrial machines (Avid CNC and the like).
Spindle speed is where my interest would be, especially if you're doing surfacing on a regular basis. What's the largest bit you expect to use? The larger the cutting tool, the more HP you're going to need. If you're staying under a half inch (12mm) you should be fine with a 3-4hp, provided you don't plan on dropping down 2" and trying to make it all in one cut. (exception to this would be a surfacing tool where you're taking light axial cuts)
One of the bigger concerns with gantry routers is the rigidity; is the machine (z axis) going to flex when you take a heavy cut?
Seth Madore
programming2C78B
I've stalled a 1.5kw with a 1/4 tool in oak.
The 2.2kw is stronger then my machine.
shouldnt Laguna tell you what you can expect? I assume the most youll wanna do is cut a 3/4 ply in a single pass?
Please click "Accept Solution" if what I wrote solved your issue!
