Hermle Multiaxis Rewind does not work
gabriel_kochQ7X8R
Observer Observer
gabriel_kochQ7X8R
Observer
Observer
Hello.
I have used the generic Fusion Hermle C12 Postprocessor and modified it for a C40U with a swivel range of the A-Axis with +25 and -110°. The Problem is that when posting a Code with 5-Axis movements the Error Code says:
"Rewind of machine is required for simultaneous multi axis toolpath and has been disabled."
The Problem is that I can´t find any settings in the post refering to Rewinding in 5-Axis movements. In the standard Heidenhain 426 post there is a setting dealing with that. I have put quite some time in my adapted Postprocessor and don´t want to make a new one, so is there a way to implement the rewind code in my post? What has to be added to make it safely work?
Rewind of machine is required for simultaneous multi-axis toolpath and has been disabled
a.laasW8M6T
Hi
it looks like the Hermle post has no rewind logic built in
Take a look at Section 8.6 in the post guide
https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf
it has instructions on how to add this code.
Andrew Laas
Senior Machinist, Scott Automation
