- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am looking for documentation on how to correctly set up a machine configuration for a next gen VF3SS/TRT-160 A/C trunnion setup. DWO/TCPC enabled. I have it set up and working OK for positional 3+2, but I'm having issues with any simultaneous 5-axis. What changes if any need to be made to the default Haas NGC post processor? I am having trouble finding any information on how to correctly set the kinematics and Multi-Axis settings under machine configuration. I have changed the default HAAS with AB-axes to AC, but not sure how to set the rotary kinematics... or if anything even needs to be changed. I know that the TRT-160 max feedrate is much slower than the default 60RPM. Also, not sure if the default settings under Multi-Axis are correct for the TRT-160. (Linearization method, Feedrate method, etc.)
