Help with a 4th Axis toolpath
Larry1962
Message 1 of 10
Larry1962
The first picture is what the part should look like and the second is the toolpath I am getting, is there any way to get a Z move into the toolpath
Replies (9)
Message 2 of 10
daniel_lyall
More than likely it can be done how you wont can you post the file  Go to File -> Export and save as a .F3D Archive File and attach it to your next post
To get picks of your screen hit PrtScn then open paint and select past then save that pick.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 10
Larry1962
Here is the file,  The toolpath is marked V Grove 1 & 2 Thank you for any help you can send my way.  Also I tried to save the picture but it did something odd and only showed tool paths and not the part so rather than mess with it was quicker to take a pic with my phone.
Message 4 of 10
daniel_lyall
It's because it's a 2D contour you are useing, 2D toolpaths are dumb toolpaths they are not model a wear so they do what you make them do where a 3D toolpath will know whats around it and you just point it to where it is to cut.
Using a 3D contour seems to work quite well, it's getting some crash warnings because of material still there I will see if I can clean it up a bit more then post the model back.
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 10
daniel_lyall
It is the 2D contour where the problem was useing the 3D contour seems to be good I have given you 2 different contours one that has crashies one that does not have a crash.
If you look at the settings I used you will see why it does not touch the problem area, you will need to use a different toolpath in the area.
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 10
Larry1962
You are correct it does not gouge the part but it also does not machine out the pocket,  The blend at the top is not machined.  Thank you for the effort but I will have to keep looking for a solution.
Message 7 of 10
daniel_lyall
Have a look at the attached file.
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 10
Larry1962
Thank you very much for the help with the toolpath,  I was hoping to side mill the whole thing without kellering but looks like that may not be possible. I decided to use a small variation of the toolpath you provided to run the parts.
Message 9 of 10
daniel_lyall
When flow is in fusion that should be what does what you need next month hopefully.
It is the angle of the end bit where the problem is.
Daniel Lyall
The Big Boss
Mach3 User
Message 10 of 10
Larry1962
Yes, last time we did this job we hand coded it and put a Z move at the end and got it close but not perfect.  I knew we could Keller it but hoped I could learn how to do the Z move in fusion.  Again thanks for the help
