help needed with this g code
hi. I am using fusion 360 to write the g code for a part i wish to make. the ,illing machine uses mach 3 to read the code and produce the work. but when i download the fusion 360 code to mach and start the work process the cutting tool just drills into the work surface and i need to stop the run before it drills into the machine bed. what is going wrong and what is the fix. here is the first
 cut g code.
(WHEEL SLOT CUT FRONT FACE WHEEL)
(T2 D=2.381 CR=0. - ZMIN=-0.5 - FLAT END MILL)
G90 G94 G91.1 G40 G49 G17
G21
G28 G91 Z0.
G90
(2D POCKET3)
M5
M9
T2 M6
S22056 M3
G54
M8
G0 X7.486 Y5.271
G43 Z15. H2
Z5.
G1 Z2.738 F251.
S11056
X7.493 Y5.274 Z2.678 F351.
X7.514 Y5.283 Z2.621
X7.548 Y5.297 Z2.573
X7.591 Y5.315 Z2.535
X7.643 Y5.336 Z2.51
X7.698 Y5.358 Z2.5
X9.949 Y6.28 Z2.415
G3 X8.96 Y7.646 Z2.356 R11.684
G1 X6.485 Y4.861 Z2.226
X9.949 Y6.28 Z2.095
G3 X8.96 Y7.646 Z2.036 R11.684
G1 X6.485 Y4.861 Z1.906
X9.949 Y6.28 Z1.776
G3 X8.96 Y7.646 Z1.717 R11.684
G1 X6.485 Y4.861 Z1.587
X9.949 Y6.28 Z1.456
G3 X8.96 Y7.646 Z1.397 R11.684
G1 X6.485 Y4.861 Z1.267
X9.949 Y6.28 Z1.136
G3 X8.96 Y7.646 Z1.077 R11.684
G1 X6.485 Y4.861 Z0.947
X9.949 Y6.28 Z0.817
G3 X8.96 Y7.646 Z0.758 R11.684
G1 X6.485 Y4.861 Z0.628
X9.949 Y6.28 Z0.497
G3 X8.96 Y7.646 Z0.438 R11.684
G1 X6.485 Y4.861 Z0.308
X9.949 Y6.28 Z0.177
G3 X8.96 Y7.646 Z0.118 R11.684
G1 X6.485 Y4.861 Z-0.012
X9.949 Y6.28 Z-0.143
G3 X8.96 Y7.646 Z-0.202 R11.684
G1 X6.485 Y4.861 Z-0.332
X9.949 Y6.28 Z-0.462
G3 X9.339 Y7.17 Z-0.5 R11.684
S22056
X8.96 Y7.646 R11.684
G1 X6.485 Y4.861
X9.949 Y6.28
G3 X9.339 Y7.17 R11.684
X9.247 Y7.244 Z-0.468 R0.238 F2051.
X9.163 Y7.264 Z-0.381 R0.238
X9.131 Z-0.262 R0.238
G0 Z15.
M9
G28 G91 Z0.
G28 X0. Y0.
M30
HughesTooling
This comes up all the time, people buy a cheep mill with mach3, it has no limit switches so has no home position. When the line G28 G91 z0.0 is executed the machine should go to the machine home but as you haven't homed the machine it goes to the work Z0. On the post dialog look through the properties for a line useG28 and set it to no, make sure the Z0. on the machine and in the CAM match. Also go to the CAM forum and do a search and you'll find some other workarounds for your machine.
Mark
Mark Hughes
Owner, Hughes Tooling
jim_g
I use Mach3 mill also and I had to deable the use of G28 and also I had to remove the G43 tool offset. Cutting those two items out and the code run ok. G28 can be turned off when you post the code and it stays off the next time you post, but I can not find a way to stop G43 and I have to edit it out on each post.
Hoope this helps
Jim Geib|Win 10 Pro|Intel CoreDuo 2.10GHz|4.00 GB Ram|ThinkPad LapTop
