Help I have tried but I have hit a brick wall caming this small part
Stuart-H
Stuart-H
Help
I have hit a brick wall doing the cam for this small part
I have 6 mm flat and bull nose
dito 3 mm
I intend to drill the holes at 4 mm to start and bore to size
its the slope that is messing up , and most other bits I have deleted my feeble attempts so not to muddy the water
its a crank arm for a beam engine
Stuart
Mac Studio M1Max and MacBook Pro M1
LibertyMachine
Did you model this part yourself, or was it provided to you? Is slight modification possible, simply to clean it up? Talking about adding fillets and smoothing out the surfaces:
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Stuart-H
I modelled it up my self look like I made a duff job I will correct the points you mentioned
any mod are possible the only important bits are the two holes , crank throw
thanks for looking
stuart
LibertyMachine
Take a look at this toolpath and see if it does what you need
Seth Madore
Stuart-H
Thanks for you time and trouble
that looks like it will sort me out
thank you
Stuart-H
yes thats done the trick I can see my mistakes and you additions to enable the part to be made
its not a big beam engine 230 mm fly wheel with centre column be about another year to finish its just a hobby for me
LibertyMachine
You are quite welcome, and it was no trouble at all. I always enjoy helping to sort people out
Seth Madore
