- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I am new to fusion 360 as well as Manufacturing.
What I need is:
*To modify the post processor to activate A and B axis (A is mounted in Z axis and B is mounted in Axis).
*Give the limits of A and B {(A will be -180,180)(B needs to be -120,120 )[I use 0 as center]}
*To make sure the Machinning limits don't exceed the soft limits of my machine.
*That the mach3 software tool path shows the right path.
What I'v been doing so far:
I have a no brand CNC 5Axis Machine. I've been using mach 3 post processor with 3 axis (XYZ) and works just fantastic, The problem is when I try to run the 2 extra axis (A and B-head to head-).
I have been doing research and learning about rewriting the post processor, I have also been reading all over the place and I could not figure out how to do it right. So far I can make it move the 5 axis at the same time but does not follow the specific path. In mach3 software it shows the right path but when I execute the program on my CNC machine it does not respond correctly. I am running out of ideas of how to modify the program so some assistance will be really appreciated.
I have been following step by step the forums but no luck so far with modifying the post processor.
The main post processor for my CNC
for the 3axis, I use "mach3mill" (Which I try to modify with no success).
The one I found (in fusion360 forums)for the 5axis is "mach3mill X axis A and B" but this does not work right (I been trying to modify with no success).
The most resent I've been trying is the "Current progress 5axismaker1" I did modification on my program mach3 software (Using A as C axis).
Thank you in advance!
