Having trouble setting up a 2D chamfer with multiple passes.
chrisQX8DX
Message 1 of 19
chrisQX8DX
hey everyone ...
so unfortunately my machine has a really weak spindle and also i'm cutting materials that tend to tear out and burr a lot. So ideally when chamfering a hole for a screwhead i would love to be able to cut in several passes. I haven't figured out how to approach this. Granted that for this small holes i could just use a drill operation using a chamfer mill but i also want to chamfer edges and other features so knowing how to do this would come in handy 😊
Could someone maybe give me some pointers, i tried searching the forum and youtube but couldn't really find anything usefull.
Here's a demo file with the manufâcturing space all set up:
AppleSilicon Macos 26.4
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Replies (18)
Message 2 of 19
weber_dominic
You can adjust the end height by the desired step with a duplicated toolpath
Message 3 of 19
leo.castellon
This is one of those things that I wish Fusion offered, multiple depth passes on chamfer. Sure, we can duplicate the path and have the previous pass leave a small amount for the last pass to finish it, but this is silly. When chamfering harder materials, like SS and titanium, having the ability to have multiple depth passes would be greatly appreciated to lessen the wear on our cutters. And you could also say, well, if you want to have multiple depth passes, then use contour and if you are using a chamfer mill or spot drill, then you get the option to have multiple depths, even a radial finish pass, well then, how come 2d chamfer doesn't have these options. The algorithms must exist as they are present in contour, so just add them to 2d chamfer, and if you can't add these options, then just get rid of 2d chamfer all together, IMO.
LeoC
Message 4 of 19
chrisQX8DX
hey sorry for the late reply ... the forum software wouldn't let me post yesterday for some reason.
@weber_dominicthx for this, i kinda knew i could do this by duplicating toolpaths .. i thought there was a way to set up multiple passes in one operation because as @leo.castellon said it's a bit silly not to have this option esepcially if you are working with harder materials and/or like me have a weak spindle who just can't handle a one pass.
Message 5 of 19
seth.madore
We do have a task opened to investigate the feasibility of adding multiple depths to chamfer, and you're not alone in thinking this should be an option (it really should be). CAM-34654 is the task, and I've added this thread to the ticket.
Seth Madore
Message 6 of 19
chrisQX8DX
thx @seth.madore that's great to hear 😋
Message 7 of 19
cnc7S6VJ
Has there been any movement on this?  I have a couple different operations involving large chamfers(larger than the tool), which are currently killing me.  None of the workarounds result in the desired tool path/outcome.  I've been fighting this, and a 30yr old mazak mill, for two weeks.  MasterCam could have done this in about ten minutes (my job doesn't want to pay for that).
Message 8 of 19
programming2C78B
Duplicate it with stock to leave as a roughing.
Please click "Accept Solution" if what I wrote solved your issue!
Message 9 of 19
cnc7S6VJ
"Duplicate it with stock to leave as a roughing. "  I don't know what those words, in that order, mean.  ???
Message 10 of 19
programming2C78B
take your chamfer toolpath
duplicate it
add Stock To Leave to the top one
that first path is now your "roughing"
edit: i see now the tool is smaller than the chamfer. Google will help ya 😉
https://forums.autodesk.com/t5/fusion-manufacture-forum/large-chamfer-small-tool/m-p/11486805/highli...
https://forums.autodesk.com/t5/fusion-manufacture-forum/large-chamfer-with-multiple-depths/td-p/8297...
https://forums.autodesk.com/t5/fusion-manufacture-forum/chamfer-toolpath-how-to-machine-a-chamfer-lo...
Message 11 of 19
cnc7S6VJ
None of these "solutions" work with an actual chamfer tool. Either the toolpath fails to generate altogether (95% of the time) or the chamfer is the wrong size(+.100 too big) when machined, the toolpath was sketchy but I figured I'd give it a shot.  I've used the ramp function to rough out the material with a flat endmill, but fusion refuses to generate a toolpath for a chamfer tool.  I watched the video you linked a few days ago and that works great for that use case, but the straight line chamfers around the perimeter of my part are driving me insane.  I have tried every single suggestion google has to offer over the last two weeks and nothing works.  A simple option in the chamfer tool might fix this, but I have zero faith in autodesk actually fixing a problem or adding a useful feature.
Alos, I updated the diameter of the tool I was using to rough out the chamfer and the toolpath broke.  WTF?
Message 12 of 19
programming2C78B
Is your tool defined with a tip size?
.1 off means something is wrong in CAM or physical setup.
If youre just doing a profile chamfer, you can also just offset with Stock To Leave if you know the angle ie: a 90* chamfer is offset 1:1 so +.1 on radial, -.1 on axial
Message 13 of 19
Don.Cyr
One of the most important things is to define your tools correctly or you will never get the correct result and that's not the fault of Fusion (or any software for that matter)
You can rough the chamfer with a square endmill and finish with 3D contour, parallel, or even flow and get pretty good results.
Please click "Accept Solution" if I helped with your question or issue.
Message 14 of 19
cnc7S6VJ
Turns out the correct answer is a custom taper tool with the EXACT dimensions of a chamfer tool, using the ramp feature.  I hate this software so much.
Message 15 of 19
programming2C78B
"None of these "solutions" work"
>"Turns out the correct answer is a custom taper tool"
Ok, so my first solution DID help you. Thanks for clicking "Accept Solution" as I solved your issue.
Message 16 of 19
josh84Q3W
Chamfer using the 2D contour tool path, then add stock to leave. Click the chamfer box in the passes tab.
Message 17 of 19
cnc7S6VJ
It half worked.  I'm not accepting this as a solution to a problem created by the developer that should have been fixed years ago.  It's a workaround, at best.  One that shouldn't be necessary.  Calling this a solution only incentivizes Autodesk to do nothing about the actual problem.
Message 18 of 19
programming2C78B
No, calling this a solution merely increases its ranking for when someone in the future looks up the same issue. Dont worry, Im sending Autodesk plenty of things to improve on every month.
Seth, does anyone report anywhere nearly as much as I do? LOL
Message 19 of 19
seth.madore
Nope, you're a right proper pain in my side because of it 🤣
(all good, keep them coming!)
Seth Madore
